1989 Evinrude 110 lower unit removal
RichT
I want to remove my lower unit to replace the water pump. I am having trouble seeing how to release the shift rod. I have the manual and see it tells me to remove the clip just behind the throttle linkage, but I can't see how this will release the shift rod which is another 3 inched toward the center of the engine under the lower carb. Any advice.<br /><br />Thanks
Chinewalker
Re: 1989 Evinrude 110 lower unit removal
When you remove that clip the whole shift arm will move sideways, releasing the shifter...<br />- Scott
Walker
What Chinewalker said. Remove the clip and push in on the linkage.
RichT
Thanks for the info! I thought about removing the lower carb to get at it, but figured there must be an easier way
