1989 evin 8hp nozzle well and hose
pointblank1000
How critical is the nozzle well and the small hose as far as a good running motor is concerned? I noticed the well has a small crack at the embedded brass tube and may leak. I may repair using jb weld. Also how tight does that little hose need to be ?
Honorary Supreme Mariner
That little hose is expensive and needs to be there.-----It needs to be tight.
oldboat1
Don't forget the upper and lower gaskets, and the high speed jet. Important little assembly.
pointblank1000
I tried some yellow chainsaw hose but it seemed too loose so I am ordering the hose from dealer. Yea 2" of hose almost $10
what does that hose do?
Look at the well very closely.----I believe you will find wee holes that meter fuel.-----That hose feeds fuel to the idle circuit.----So yes it is important.-- That hose needs to be installed so it does not interfere with operation of the float.-----Give yourself a pat on the back for asking too.
pointblank1000
That's what I thought. The oem hose came apart and the .040 office was dirty so I cleaned everything but did not have the hose. It's on order. Thanks
pointblank1000
IMPORTANT: I just noticed in the carb on the BRASS tube that the little hose goes on "at the bottom of the tube" I can see two SUPER small holes perpendicular to the tube. Should the hose be pushed all the way down to cover those holes or should I stop the hose short of covering? I saw these holes using my magnifying glass.
pointblank1000
Ok, I installed the hose and made certain the hose did NOT cover the little holes. The motor started and ran good.
ALso, I bought the hose 2' for $4 at a lawnmower repair shop.
F-4040-a o.d. .125. Wall thickness of .030. It fit tight and worked well.
