1989 cylinder head and intake torque specs
Can somebody help me with torque specs for the cylinder,intake,thermostat housing.. I ordered a maunal but I won't to get this done ASAP so I can get back on the water.
Re: 1989 cylinder head and intake torque specs
Ayuh,.... Welcome Aboard,... Whatcha workin' on,.... Quite a few motors from '89,....
Ayuh,.... I believe it's 65/ 70 ft.lbs on the head bolts, 'n 25 ft.lbs on the intake,....
Check google to verify,...
Ayuh,.... When ya set the Intake,.....
Toss the rubber end pieces of the gasket set, 'n use silicone rtv,...
Run a fat bead across the ends, let it skin up, Then set the intake, 'n bolt it down,....
Btw, don't forget oil on the blind hole head bolts, 'n sealant on the wet hole bolts,...
Ok I won't and thank again you been a big help..
I posted another thread with my lower unit leaking gear oil. Do you have any clue where it is leaking from and what I might be able to do to fix it.
Ayuh,... I don't do Cobras,... There's a seal leakin',... take it apart, 'n find which 1....
Idlespeedonly
More than likely it will be the shift shaft seals. But as bondo said, only one way to find out.
