mattkenton
Thread starter- Joined
- Nov 4, 2008
- 106
Ok so i was running the engine on the muffs yesterday and i touched the port side of the block and it felt a little warm, not bad. Felt the starboard side and it about left a blister. I turned off the engine and opened up the thermostat housing. Thermostat was dry on the backside that opens up. But my tell tale was peeing just fine. Should the tell tale pee if the thermostat is not opening? I think it is time to replace both thermostats just to be safe. They are super easy to get to.
I looked inside and did not see any major salt build up. Just a slight bit of wall crud. Maybe a mm or so.
I am def going to replace the thermostat but would like to test it to confirm my theory of it not opening up. Do i do this just like a car thermo, in a bowl of boiling water with a thermostat?
Thanks.
Thanks.
