Re: 1989 Celebrity 181-Tach stopeed
Because you have power INTO it is only part of the power issue. Unless the instrument has a good ground, it won't work either. Likewise the send signal on the "S" terminal must be present as well. That signal comes from the ignition system (the coil) on the engine. If all three of those are present, then the instrument is toast. They can be repaired but will likely cost more than a new Tach.
