1989 bayliner with a AQ125 volvo penta always overheats
dongil
I have checked everything and replaced the water pump, impeller and thermostat, just cant seem to draw raw water up to the heat exchanger. Any help PLEASE
Don S
Re: 1989 bayliner with a AQ125 volvo penta always overheats
Bet ya haven't, or it would't be overheating..
Check the water hose connection on the outdrive, just under the ujoint bellows. The hose connection corrodes away just inside the hose allowing air to be drawn in, instead of water.
If you are running on muffs, you may not have enough water pressure, turn the hose full on and make sure you plug the secondary pickup on the bottom of the outdrive. It's about a 1/2 round hole.
dongil
Thanks, will give it shot
dongil
I checked it and it is not corroded looks new I think it was replaced befor I got the boat. Anything else
captmello
Does it over heat under all conditions? Idling, running fast, When you pull the cap off the heat exchanger, are you seeing good flow of raw water?
Do you boat in salt water? how about the previous owner?
dongil
It runs hot all the time. Never in salt water and there is no raw water flowing in the heat exchanger, Thats why I replaced the impeller. About ready to go boat shopping
bruceb58
Put a clear section of hose between the inlet hose and the water pump to see if you are sucking air.
