1989 Bayliner 125 hp Force L-Drive OVERHEATING!!
Ohiodeerhunter
I have a 89 bayliner capri. I just got it running good and the motor is getting really hot like its not getting water to it. I replaced the water hose with a heater hose from autozone. Does it have to be hose with wire for the pressure. Maybe its sucking the hose shut. Any ideas?
pnwboat
Re: 1989 Bayliner 125 hp Force L-Drive OVERHEATING!!
The water hoses on the L-Drives are under positive pressure. I doubt that you have one sucking shut. Have you replaced the water pump impeller/assy. and thermostat?
