1989 88 SPL Compression
Deckworks
I just bought a 17 foot Sunbird Center console. I am awaiting a new/used lower unit since I believe the one on the boat is shot. Lots of Metal flakes in the lower unit.I took it out today with the old lower unit. I could only reach 4200 rpm and 30 mph with gps. I have 100 lbs. compression on all 4 cylinders. New power pack. Is it my lower unit and prop that is not getting me what I need. I read I need 52-5600 rpm. I'm not near that.Is my compression too low? Any help would be great. :redface:
ezeke
Re: 1989 88 SPL Compression
The compression sounds as though it is OK. You are probably over-propped. Do you know the pitch of your current propeller?
Deckworks
13 1/4 x 17 But it is banged up. Not missing any chunks though.
I'm not new to boating. I also have a Sea Ray 215ec that I do all the maintenance on. I have owned many 2 stroke motors but only up to 40hp. I really was concerned with the compression being to low even though all cylinders are all within 10% of each other. If that is fine, It has to be the prop and/or lower unit. I'm guessing.
ezeke
You can try to raise the motor higher on the transom which may help. The boats I think were rated for 115HP so I think that you are in the right power range. I would guess that with a good propeller and maybe 15 pitch you will be where you need to be.
Check the plate for the rated horsepower.
You may find that a thorough de-carbon treatment will improve the compression.
Deckworks
WOW !! Your spot on. Boat is rated at 110 HP. I have read many posts that say to decarbon the motor. Is that just adding sea foam?
I will also try the 15 pitch prop. Thanks for all the help.
