1989 85hp force
6eor6e
Hi I have a 1989 85hp force and I can't get cylinder 1 to start when I turn on the motor. there is spark going into the plug but it just wont get going. I changed the spark plugs and took apart the carb cleaned is out but it still didn't start. when I start the motor up cylinders 2 and 3 get going fine but 1 is just dead, the only thing that happens is gas comes out of the little valve above the carb bulb. any help would be great thanks
steelespike
Re: 1989 85hp force
Not sure what the "carb bulb" is but if you have gas coming out then it is flooding possibly a poorly adjusted float or stuck or dirty float valve.
Is the choke operating correctly?
6eor6e
Re: 1989 85hp force
sorry I wasn't sure what to call but (carb bulb) it's the part that the float is inside of. my boat has twin force 85's maybe I will try to switch out one oftthe carbs from the other motor to see if it will make a difference
