1989 85HP Force has no fire.
will2222
I have a 1989 85HP force. It was sitting for a few years and I took it out and found that it was running on two CDI box so I started unhooking it with the battery still hooked up unfortunately. I put new box and stator on and now I cant get any spark. I checked the rectifier and fuses checked out. The only other part I can see that I could of blown is whatever the part is under the stator that has 6 wires coming off going to the CDI box. Any Ideas?
jerryjerry05
Re: 1989 85HP Force has no fire.
First is there a kill switch? Second check the magnet on the flywheel, sometimes they come un-glued.Third get a manual and test the parts.Don't just replace them.If you wanna just replace I just listed some parts on e-bay and it is a stator and trigger and some other stuff.J
