Re: 1989 85 hp to a 1990 hp outboard force
Yes! The mounting is the same and the crankshaft splines are also the same. You did not say if the 1990 was a 3 or 4 cylinder but it doesn't matter if you are not trying to use electronics from a three on a four or four on a three. They have different triggers. However the 89 and 90 (3) cylinder electronics are exactly the same. Therefore if both engines are three cylinder, it is a direct swap and you have your choice of which electronics you want to use--assuming both engines are complete with electronics.
To access the mounting bolts you need to remove the rear shroud. remove carbs, starter, electronics, and head to make the block lighter and prevent damaging delicate components. 9/16, 1/2, 7/16, and 3/8 wrenches are just about all you will need. There are six 9/16 head bolts on the front of the match plate and six 9/16 nuts under the rear shroud.
The only problem you will have is corrosion around the mounting studs where they pass through the midleg. They tend to be tight and you will need to carefully pry at the pry points. Sometimes it can be frustrating. Because of this, you will need to remove the lower pan for room.
If you leave the exhaust down-tube connected to the block, you will not need a new base gasket, just a little black RTV silicone.
The block is a bit heavy so it if you don't have a lift, it pays to have a friend help. To remove or reassemble, the exhaust down-tube has a flange that interferes with the water tube mounting so the whole block and down-tube must be twisted a bit to clear it. That's where the extra hands help.
While you have the block off, look on each side of the leg flange at the front motor mount bolts and washers. They tend to rust. Remove the bolts and replace with same length 3/8 stainless bolts. Replace the washers with extra thick stainless washers if you can find them. You may need to grind them a bit to fit. If you can't find them, coat the washers with a good amount of RTV silicone just before you mount the replacement block. Replace the bottom mounting 3/8 bolts with stainless also.
