1989 85 hp force lower unit froze up
powercam
i took the water pump and plate off the top of the lower unit.<br />i can see the bearing and pieces of metal.<br />does any one know how i can get to the bearing?<br />how do i get that spacer or nut? out to get to the bearing.<br /><br />thanks a mill
DeFeet63
Re: 1989 85 hp force lower unit froze up
I am in the same boat as you...I have taken my 85 lower unit all the way down. I used the Seloc manual to help. Not hard, but a few little tricks. The next step for you would be prop shaft removal, then the driveshaft will come out. I would highly recomend that you get a manual if you dont have one. Let me know if I can help.<br />I am in the proccess of replacing my gears and bearings....I hope. Good luck
