1989 75 elpto hyd. Fluid in tilt motor
Musky killer
Tilt motor stopped working, Brushes shot. Which seal stops fluid from entering tilt motor?
RRitt
Re: 1989 75 elpto hyd. Fluid in tilt motor
look into reservoir. there is an armature seal in top of reservoir. you may find that worn bearings are the root cause of your oil seal vibrating out of place. check for internal rust. if there is any internal motor rust then it is probably bearing and you should just buy new motor instead of throwing good money after bad.
