River Rider
Thread starter- Joined
- Aug 10, 2009
- 48
Well after having the block completely rebuilt and have ran it through the break in period I have a problem. All was good till the last time I was out and the motor seemed to stall out on me. Almost like it was out of gas. So I throttled back and killed the engine. I check the tank and could see there was about a gallon left in the bottom of the 19 gallon fuel cell so I thought maybe the pick up wasn't all the way in the bottom of the tank so it was starved for fuel. I loaded the boat and left. The next time I took it out with a full tank of gas it would turn over but never crank. I don't have a kill switch wired up so I know it isn't that. So I took it home and checked fuel lines, filters, and pump. Everything seemed to be working so that is when I checked the plugs. Plugs looked good as they were brand new and I checked the coils with an ohm meter and they showed to be good. After reading on here it must be the power pack because it would be real bad luck to have all three coils go out. Well this past weekend I put the brand new omc power pack on and still no spark. I was told to check all wires and battery cables. I rewired the ignition switch with a new power harness. Put new battery cables and cleaned up any nicked wire on the block as well as organize the wires in looms. After all that still no spark. I am lost now as to what it could be. Stator? Slow Starter? Something completely simple? Any advice is greatly appreciated. Thanks
