1989 60hp evinrude. Cranks but won't start
oldboat1
This thread has a pic of a '77 Evinrude 55hp timing mark: http://forums.iboats.com/forum/engi...boards/10138643-johnson-55-i-can-t-figure-out See post #8.
You have a different flywheel style, but the method is similar. Get the piston in position as described, or just skip it for now. Best not to get side tracked -- stick with the basics. Review starting procedure, check spark, compression, etc. These tests are the routine stuff you would be paying a shop to do.
????----It will not cost " too much " to have a shop check for a sheared key.-----Sorry, if you mis-understand the coaching posted here for you to check it yourself.
tphoyt
Cant stress enough how much fresh gas is important these days.
