1989 50hp force toque and sequence specs.for head?please help
forcefisher
I have a 1989 50hp force I just bought A head gasket. I checked and cleaned the head.Ready to put the gasket on,but their is one thing stopping me, I do not have the tightening sequence, or the inch pound head bolt specs.(please help!) thank you!!!
fishin1789
Re: 1989 50hp force toque and sequence specs.for head?please help
There are 2 different specs listed in the Clymer manual for a 1989 50hp. If it is a 1989B it will have 3/8" bolts that are torqued to 270 in.-lbs. If it is a 1989C it will have 5/16" bolts that are torqued to 225 in.-lbs. To torque start torqueing in the center and work your way out! Hope this helps!
Mother
ForceFisher's is right, I just checked my factory manual for 35-50Hp, 1989-1991 and the text says:
"Torque in sequence to 75 in. lbs. (86 kg/cm) then torque in increments
of 50 in. lbs. (57 kg/cm) until a torque of 270 in. lbs. (310 kg/cm) is achieved."
With the spark plug openings (@) oriented to the right side the torque sequence is
7 8
3 @ 4
2 1
6 @ 5
10 9
If the image comes through (I hope) :confused: this is how that looks in the book.
I think if you click on the image it will enlarge.
Good luck - Chris
forcefisher
THANK YOU for the specs :D I was looking and I can see some water got in to the engine block:eek: do I have to tear the whole engine apart to clean it out, or will it burn out when I run the engine:confused: I was able to get the water out of the head, but I can not get to the rest of it in the intake:confused: Also the two bolts in the bottom of the head have black soot on them so I looked A little closer and the thread holes go all the way to the inside of the block. is this normal:confused: if so should I use A sealer on them? or should I just get A couple paddles:( my model # is 5200371039 or 507y9b ? I am wondering if there is two types of gaskets if their is two different torque specs.thank you guys!
forcefisher
I just looked and I have the 5/16" head bolts.I have the 18-3853 head gasket is this the right one. it said it replaces force #27-f691529-1 fits 45 and 50 hp.their are two different head gaskets for 1989 50 force.thank you
Mother
Hi ForceFisher,
First - to level set the bases, I am not a marine mechanic. I am a retired electro-mechanical engineer/designer with a fair amount of hands on repair experience. I have never disassembled this motor to its internal components.
Second - for your reference, I am restoring a 16ft Blue Fin Spectrum model 1606JA with a 1989 Force 50Hp, model number 507Y9B, serial number 1561, 20" transom outboard. Your motor, same model as mine, is listed on the front page of my factory parts list as a Spectrum 1989 "B" model. Is your boat a Blue Fin Spectrum?
Third - Your questions in inverse order:
Head gasket part number: My factory part list "OB4275" is for the 1989 "B" model. It lists "Item 13 Gasket, cylinder head" as part number 691529. The head bolts, "Items 17 part number 2254, Screw, cylinder head and cover to cylinder" are 5/16 - 18 x 2-1/2. Again, my factory manual calls for a final torque of 270 in. lbs. for the 30 through 50Hp 1988 - 1991 models. No mention is made regarding different bolt sizes. I do also have the Clymer manual and see where Table 5 "Cylinder Head Bolt Torque Specifications" calls for 270 in. lbs. on 3/8" bolts and 225 in. lbs. on 5/16" bolts. What goes on there?
I called Mercury Marine and their support people checked for updates or errata on that manual. They verified the final torque value to be 270 in. lbs. as stated in the manual. If you are still concerned about the different answers go in the middle - 248 in. lbs. That is about the best I can do for you.
Water in block: I do not know if attempting to start and run the engine will purge the remaining water. I can see that water might have gotten into the transfer ports as well as the exhaust. The soot on the bolts is probably caused by exhaust getting around the bad head gasket. The manual does not specify any sealant or thread locker to be used during the installation of the head bolts. Lubricating the threads of a fastener will change the final impact of the torque. Did you check to see if the cylinder head was warped? Pretty much greater than 0.012" and it is Sushi. IMHO if the head is flat and gasket is installed and torqued properly you should not have any exhaust soot or water blow by.
If you must open the transfer or exhaust areas to clean and dry them you will need to acquire new gaskets to install as you reassemble the power unit.
Perhaps you could post some pictures of the problem areas then someone else on the forum may be better able to answer your questions than I.
Sorry about the delay in answering; I've been sick.
Good luck, Chris
