Clicking probably a weak battery or loose/corroded connection on battery terminals, ground, or on side of starter...remove/inspect/clean/ grease/tighten each one....if that doesn't do it then have your battery checked....what is the age of the battery?....the main battery cables can develop corrosion on the inside of the rubber/plastic cable jacket...check them out!
I second what robert said. The same thing happened to mine when I had a weak section of battery cable. It would happen to my last motor as well when the battery was low.
