gaforce1989
Thread starter- Joined
- Mar 26, 2014
- 4
I have a 1989 Force 50 hp (507Y9B) that had a broke ring and a damaged piston. The cylinder cleaned up nicely and was within specs according to my SELOC manual. So I was just going to replace the piston/rings (Standard bore) and seal it back up. I ordered a piston from iboats thinking it was the F694015 replacement, well I received a replacement piston for 834794T3. The website states this is what has replaced F694015. The original piston wrist pin is retained with clips, the new piston has a slip fit wrist pin on both sides of the piston with no provisions for any type of clips. Im confused because I cannot find any clear answer as to whether or not this is correct or a casting flaw. Any info would be appreciated. Thanks
