1989 40hp starter motor on 86 vro evinrude
Lucky7ns
Some how when I ordered the starter for my 86 months ago I didn't realise it was different from the 89 with the b+ terminal on the lower starter case was in the wrong location, can't return it now its been some time, it hits the case portion where the quick connect fuel line goes, the vro is bypassed. Was wondering if I could disassemble the starter and rotate the housing 180 degrees to relocate the terminal, and also does the difference between the rubber style drive gear and the metal style differ for the flywheel and engagement of the starter. Both are 9 tooth and the housing for the starter appear to have the same mounting locations for the block.
dont really wanna buy another one but if I have to I will.. as far as i know those are the only two differences between the 86 starter and 89..
any input would be great
