1989 4 hp E4RCEC
WayneMullannix
I have a 1989 4 hp model E4RCEC that start right up but runs for 3 to 5 minutes and shuts down. I have put a new water water pump kit in and am getting a small spray from holes but head getts pretty hot. Is there possibly a problem in upper end and if so how doI get to it? Also does anyone have pictures from service manual that I could use to get to problem?
hardwater fisherman
I have a 1977 4hp that was doing the same thing. It turned out to be the fuel pump. If you are touching around the spark plugs or the exhaust plate it will be hot.Did this problem start after you changed the water pump? When it shuts down do you need to refill the carb by pumping the fuel bulb?
Vic.S
As already said the cylinder head around the spark plus and the exhaust cover plate will be very hot, else where it should be possible to maintain light finger contact briefly. If not then very probably overheating. The water channels between the power head and the top of the exhaust housing and the channels around the cylinder head can become choked, especially in a salt water motor that is not thoroughly flushed after use.
However the length of time it runs before shutting down suggests there may be a problem with the fuel pump or fuel flow to the pump.
Try pumping the priming bulb repeatedly. If that keeps it running then it is a fuel problem. It may be a defective pump or there may be air in leakage into the fuel line.. A bad O ring in the connector can cause the latter.
Your motor is covered by the manual at http://boatinfo.no/lib/evinrude/manu...inrude.html#/0
I
f you do end up overhauling the fuel pump it is vital that you dismantle it carefully and systematically noting how it is assembled or you will never get it together again.
There is some useful guidance on LeeRoy's ramblings
http://www.leeroysramblings.com/Outboard Motor Related/OMC outboard related articles.html
WayneMullannix
I feel like a dummy but I think it is fixed. I took the lower unit gearbox back off and found I had not gotten the water tube back in place properly. This let the pump put water back up into the lower unit and out through the holes but was not putting water through the cylinders.
I ran the motor in my barrel for 10 minutes and it never got hot, I could lay my hand on the back of motor under the cowl and it was just warm. It ran great at idle and high rpm and in gear and out. Guess I can now go fishing up and down the creek with or without a paddle.
Thanks for all the input, I appreciate it all.
