Oshawapilot
- Aug 2, 2013
- 66
Hey everyone - I'm helping out a relative who owns a 1989 Sunrunner 302.
The boat is equipped with the twin in line four cylinder MerCruiser 470's and Mercruiser outdrives. Yes, there was plenty of discussion and thought about these engines before purchase based on their checkered history however like I said the boat was purchased two years ago and they are still both running well with proper maintenance. I had a thread here at the time of prospective purchase and lots of the usual "run away!" posts...but here we are 2 years later and they're both still running perfectly.
So, moving on... It's primarily used as a slow speed Lake cruiser spending probably 80% of its time barely above Idle cruising, and 20% of the time up on the plane but never above 3500 RPM.
My question is with regards to props – neither were in particularly good condition when the boat was purchased however suffice to say there was an incident a few weeks ago which now necessitates changing both of them.
We are unsure if what's on it is even the original designated props, or what would be best. It's hard to tell as the part numbers were damaged or hard to read but I believe the current props are 16" and 16 pitch. Does that sound right given a 31' (roughly 8-9000 pound) boat with 190-200 hp (but torquey as the 470's were known to be) engines?
Would there be better options for replacement? Again, this boat spends most of his time at low speed however some get up and go is appreciated at times so we do not want to prop it for strictly low-speed. With what's on it currently performance was decent and fuel economy was stellar so they wouldn't want to sacrifice the economy side of things.
Thanks!
Regards;
Mark
Thanks!
Regards;
Mark
