1989 28 hp water pump-thermostat
ldahlka
I have a1989 johnson 28 hp J28 ESL CEA and whistle comes on from control box. I bought a waterpump kit,but cant find a exact video or instructions for installation-anyone can help? Also does it have a thermostat-seen that in alot of responses.
F_R
Pretty easy. Remove the oval plate from the side of the midsection, then remove the lower bolt from the shift rod connector inside. Remove 5 bolts holding the lower unit on. Lower unit will now come down and off, and water pump will be right in front of you, around drive shaft.
Yes, it has a thermostat, but they get a lot more bad press than they deserve. If you insist on looking, it is behind the thin cover on the cylinder head.
