1989 260 5.7 Torque Specs
CRay45DB
Hi,
Rebuilt the Rochester Quardrajet over the winter. Started right up. Reason I rebuilt it is I had a vacuum leak I could not find. Started it yesterday, started right up. Looking in the book I cannot find the tourqu settings for the 4 bolts that hold it down. I know it wasn't tigh enough as fuel was leaking from the ottom.
When it comes to the low speed two mixture screws, I counted the turns when I removed. Both were 4 full turns. But the manual says 1 1/4, but others say 4. Any idea? And my idle is too high, round 900. I know I need to set the low speed screws. Enforce I can adjust.
So to summarize:
1. Torque specs for Carb?
2. 1 1/4 turns of 4 full turns for low isle.
Thanks!
CRay45DB
Re: 1989 260 5.7 Torque Specs
Also, having a brain fart, isle speed screws in leans it out?
Hi,
So to summarize:
Thanks!
Ayuh,... I believe the carb is torqued to 'bout 20 ft.lbs...
the turn, 'n a 1/4 is merely a starting point...
Both,... turn 'em In, is leaner... Out, is richer idle...
