1989 25hp Johnson - No Spark
clokken
Please help. I was cruising along and the motor was running fine and then all of a sudden it abruptly quit. There is no spark at either plug. Could it be the power pack? Please give me some ideas.
Thanks,
Cal
fireman57
Re: 1989 25hp Johnson - No Spark
Could be. If you know where there is a spare that you can use for test purposes before you buy one try it. Remove and clean all your connections first. If this is a rope start check your 20 amp fuse that is in a holder on the side of the engine.
