I have twin 200 hp mariners (1989). The engines are smoking alot running rough at low speed, and the alarm sounded when I increased to about 4500 rpms (but not every time)stopped when I throttled back, also they sounded for a couple minutes when I started them at idle speed. Compression on both is pretty close, 130 to 135 on five cylinders 110 to 115 on the sixth on both engines respectively. Got plenty of oil, water running through pee holes O.K. Should note that the engines were not run at all last year, and only a few time this year. Maybe needs tune up. Any ideas.
