crazycajun25
Thread starter- Joined
- Jun 9, 2006
- 26
i have a 1989 150xp vro that is shuting down after you start it question is if the vro pump is getting bad on the gas side of the pump will it shut the engine down so it doesn't fill the carbs full of oil ? i have replaced the fuel lines,filter, s plugs checked p packs all seems fine. when it shuts down if you squeeze the primer bulb you can hear something click then it fires right up
thanks again
thanks again
