When you say to make sure I have the idle speed set right would this cause the problem? I use the motor primarily for trolling, sometimes as slow as .8 MPH to 1.8MPH. Would this slow speed cause the unburned fuel to leak out of the exhaust (and I?m still not sure this is the cause)? If this is the cause, is it doing damage to the motor and is there a reason for concern? This has always been a great motor I have never had a problem with it until just a few weeks ago when it wasn?t idling right. The cam roller was bad and once I got that fixed is when this new white foam problem started.
