1989 125 hp force outboard wiring diagram
Trevor1977
just got this 1989 125 hp force outboard with the ignition wiring ripped off does anyone have a wire diagram?
jerryjerry05
There should be a buss bar and next to that on the exhaust cover should be a strip with the wiring and color code.
Not on your motor?.
Trevor1977
yes you may pm me. i have moved on from that force motor and am working on a 1979 apollo 21' /w an omc 190, i am having problems with that if u can help mostly its electrical. has a wicked power draw and an ignition switch that wasn t completely wired. ive bought a new starter the old one tested dead. new selinoid thought i got it wired up right hit the key switch and i got crickets no not even crickets no sound no nada i hooked up a temp remote push button switch and it will turn the motor over no accessories on nothing but the starter, selinoid. which in therory shouldnt the motor fire up and run? just no kill switch and no way to turn it off if the ignition switch is dead?
