1989 125 Force Prop
JDANIELSETLIFF
what kind of props are yall running on yalls 125s mine has scratches where previous owner hit concrete boat ramp looking to see what works best
jerryjerry05
Depending on the boat and size and load??????
The 89 125 came with a 17p or a 19p
Depending on the size boat, it can use as low as a 13p(pontoon) 15p= big boat.
Unless the blades are completely gone?? then the prop can be rebuilt.
About every marine repair has access to a prop shop.
On your prop is a # stamped in the side or on the end where the nut tightens.
Post yours.
If you need there is a prop forum here.
Also Michigan Propeller has a prop service.
Give them the info on the boat, they can recommend the right prop..
SkiDad
my 19' bayliner was much happier with a 15 pitch. iboats sells them on this site, look for Michigan Wheel props. Post a picture if you get stuck.
