1989 110HP Johnson motor shutting off
matt423
I have a 1989 Johnson 110HP. I can hook up the water hose with the muffs and it is a little sluggish at first to start up but once it gets running it runs great I can put it in gear and no problems. But when I get to the lake I put it in gear and it gets to about 5mph and then shuts off. I have had a compression check done. I have also changed all four coil packs on the motor because 2 of them looked burnt. I have replaced the water pump due to the fact it was pretty old. I had the carburetor cleaned and redone last year. I have also replaced spark plugs but still has this issue. I am thinking it may be fuel pump or power pack. How can I check these to know for sure? Any other HELPFUL suggestions will be great.The model of the motor is TJ110TLCEM Thanks
jakedaawg
1st, try running with hood off.
Report comprrssion check #'s
Report results of open air gap spark test set to 7/16"
Report results of fuel sample into a clean jar.
After these you will preform a cylinder drop test while in the water. Pull off each plug wire one at a time while in gear at idle. Note if there is an rpm change. Dont bother with this test til others are complete.
emdsapmgr
You really can't compare anything to running the engine on the trailer. That engine will seem to run just fine on only 2 cyls when on the trailer. Your ear can't tell the difference. The difference is when the boat is in the water and you put it under power. The cyl-drop test will confirm which of the plugs are actually firing..
