Re: 1989 110 omc ob ignition problem
Hey boanut....welcome to the forums!<br /><br />Well....to start....you probably switched out the reg/rec for nothing. It don't do much for spark.....just charging the battery is all it's good for.<br /><br />Possibilities....weak/bad power coil under the flywheel, could be the power pack. <br /><br />What you need to do is find out what the voltage is coming from the power coil to the power pack is. If it's OK....probably the pack.<br /><br />Suggest you get a service manual for the engine. OEM is preferred. You can get reprints of the OEM's from Ken Cook Co. or Marine.com. Do a search. <br /><br />Gut feeling....power pack.
