1989 110 johnson problems
jojododge
weve been runin this motor for two weeks and we keep haveing the same problems. first we rebuilt carbs, new fuel lines from tank to motor, and new sparkers. my problem is when we take off dosnt matter what throttle im at the motor will just shut down and fall flat on its face but also start right back up and run another 20 seconds. if im lucky i can lay back on throttle and catch it befor it dies. so we figure it was fuel pump is our only guess other itll run like a striped ass ape. i know its was the vro2 and i notcied ther is no oil tank on side. but i am mixin 50.1. so every 20 or so seconds it will die out. what kinda options and advice can i get?
jojododge
im sorry i am ina hurry so if theres sometin i can fiddle with to get going this weekend ill do and and parts id overnight it if possible
Joe Reeves
Does it make any difference if you have someone constantly pumping the fuel primer bulb, acting as a manual fuel pump? If it does, that indicates the fuel pump you're using is faulty.
You're using the VRO as a straight Gasoline fuel pump..... Is the oil side fitting side plugged so that it will not pump air?
jojododge
yes it is caped off. ive seen on other fourms that it need to be unpluged too. but its still plugged in could that be a problem? i just bought this boat like this. and also i have been lookin at getin rid of the vro and get the lil pump that mounts on side of motor if it helps me later on than dealin with this vro pump
jojododge
and i also aint tried pumpin that bulb while running yet but alot of my boat buddies has told me the same for the fuel pump bc it does sound like its runin outa fuel then waitin for fuel bowl to fill up befor nailing the throttle down
Honorary Supreme Mariner
The first thing to do on that motor is a compression test.-----Nothing else matters if there are internal issues, such as broken rings.---Report the numbers.
