1988 VIP vindicator need help loud noise no forward or reverse
usguppy84
Re: 1988 VIP vindicator need help loud noise no forward or reverse
Where would I go about getting realignment tool?
JON NEELEY
I borrowed one from a friend that had just ordered it. It was a universal for mer and volvo but a must have tool
JON NEELEY
I havent looked but in the adults only sticky there is a catagory for "make your own tools" there mite be something there?
usguppy84
Took drive off last night , engine coupler and drive shaft looked fine , manually put it in gear and I turned shaft prop spun, took top plate off filled with fluid, top gears looked excellent , took lower off upper and I put in gear the shaft spins when u turn prop if you turn the shaft prop does not spin. If I turn prop and hold shaft the prop will spin but the shaft will not. That is as far as I broke it down. Could it be the shifter is not fully engaging? I don't hear any grinding or it's not hard like a gear is broken. If I just undo the 6 screws where shift lever is out will I be able to see down in there at all?
JON NEELEY
I wish I could help on that, I would have done all you did and hoped to find the problem. Your beyond my limited knowledge:(
usguppy84
Me too, I was hoping for anything visible that I could see , I am ready to go back to the lake! But unfortunately now I am gonna take it to marina and get lower taken apart to see what's up , anyways thanks for helping much as you could , let ya know what I find out
JON NEELEY
when you have drive back on and shift in forward and reverse does the shift linkage on the drive move normal?
usguppy84
Well had the wife get in and push lever forward , the arm moves up but I can still push it up another 16th of an inch , same in reverse it may be going as far as it should still.
HT32BSX115
460 with OMC cobra
Oh no! :eek: Not another one!
Howdy,
It's possible that you have a lower shift cable problem that isn't allowing you get it into gear fully. Running it that may have already damaged the shift dogs.
But if you can place the drive in gear and you can still turn the prop, something else might be wrong.
In FWD, when turning the prop clockwise it should "click" BUT you shouldn't be able to turn it backwards.
And in REV you shouldn't be able to turn it forward (CW) and it should click when turning the prop backwards.
If you have already removed the drive, you can move the shift shaft up and down and see if the drive is shifting.
You asked about the coupler. If the engine would idle for extended periods and not overheat, chances are the coupler is ok. If the drive stops turning, the raw water pump also stops and the engine will overheat quickly.
If the drive is damaged internally, get ready for some sticker-shock. The King Cobra drive is very expensive to rebuild and there's more than a few "showstopper" parts that are no longer available (except used)
Good luck,
Rick
usguppy84
Out drive is removed, I can manually shift into geari now have lower and upper separated going to take it to shop to have them take apart the lower , hopefully at not at to big of a price, how u tell if you have a king cobra or just a cobra out drive , i know 460s came with king cobra I just want to know any visible differences in them .
HT32BSX115
You can accurately tell by the actual OMC number and you need an OEM service manual to get it.
The (Dog-Clutch) "King" Cobra that went on the back of the 460 is unique to the 460. It was attached to no other engine.
It holds 108 oz of oil making it the biggest one. If memory serves, it's a 1.41:1 ratio........ (or was it 1.43:1?:rolleyes:)
After about 1990, OMC called several different (Cone Clutch) drives "King" and bolted them to other engines. The dog-clutch 460 King Cobra was only offered in 1987, 88 & 89.
Have a look at http://www.hastings.org/~stuart/cobra/ for good operation/adjustment info, etc....
Also look at http://www.sterndrive.info/king.html and finally for OEM part numbers http://epc.brp.com
If you REALLY like the boat and want to keep it long term, you might want to consider finding a complete Mercruiser or Volvo engine and drive at your leisure for future replacement.........That's what I did about 5 years ago with the boat in my signature below........
Good luck
Rick
usguppy84
Problem ended up being a broke drive shaft , who ever put lower unit back together did not tighten the nut on the shaft tight and it broke no gears where messed up , should be back on water next weekend, thanks for all the info and advice , hope this can help someone else in the future. Thanks again.
