1988 Starcraft 1600 Medalist
rnx22
I recently purchased my first boat and I'm see the nav. lights, horn and interior lights don't work - the use the old pull style headlight switches. I tried hitting the 2 reset switches under the dash - I checked the 1 fuse in the fuse box = ok - there are 2 relays that I didn't check - the dash lights, fuel gauge work. When I was looking at the wiring it was a mess. there were several cut lines that weren't terminated etc - I found these because I had to replace the bilge pump.
Where do I get a owners manual? I tried starcraft - no luck.
Any help would be appreciated.
Re: 1988 Starcraft 1600 Medalist
Ayuh,.... Welcome Aboard,.... Even if ya found an owner's manual, I doubt it would help,...
Here's some generic wirin' diagrams to help ya figure out what goes where,...
In Boats, ya need wirin' for both the (+), 'n (-), as there's no chassis groundin',....
'n even in a tinboat, Never ground through the hull,...
