dustinsapple
- Jul 8, 2020
- 30
Hey all,
Beginner boater here I'm just getting into boats and learning about them. I myself am a backyard mechanic, welder by trade and work in a machine shop. I'm not the best of wood workers as I prefer metal but I am going to attempt to gut my floor in the boat, clean and redo everything.
I just bought my first boat this season, with a cracked block from not winterizing it properly last year. The guy I bought it from picked it up late last season only used it a hand full of times before storing it for the winter. First time he took it out this season he quickly found out water had froze and cracked the block. He dumped the boat so I got it fairly cheap on a trailer with a brand new axle.
The boat is old yes, but after having just replaced the block and rebuilt the motor, its all in good shape. The hull itself is in good shape too, no repairs or cracks anywhere and overall I believe was well maintained during most of its life. Since buying the boat about a month ago, I rebuilt the motor fixed up all the gauges and small stuff like blower motor and plumbing, bilge pump, adjusted everything I could to make the boat work as it should and run great.
I've had the boat out for day trips and have about 12 hours on the motor rebuild at this time, it doesn't leak or require me to run a bilge and overall I've been super happy out on the water. Mostly Lake Ontario I'm 10 minutes away.
I've been stuck with not being able to get anything above 4000RPM with my OMC Cobra, using a few different props and such and basically the top speed I've seen was about 40mph. Aftering going through Don's checklist of mechanical things, I'm convinced mechanically my boat is on point and that its has to be something load related that is holding me back. Weather it is or not after doing some research and discovered I'm probably lugging a ton of extra weight in rotten wood and saturated foam I've decided to redo my entire floor. At this point rather than buying another older boat with the same problems I think that it is best (to not only learn but know my boat) to fix this one up and become more educated as I continue to grow and learn about boats
I believe the floor itself is all original, it seems to be wooden, but covered in a light layer of fiber glass. This is all new to me so I am looking for some tips from you guys on what I should be doing and looking for exactly.
Attached are photos of the boat, and now with the gutted interior and the cuddy step spot where I started to rip up the flooring and fibre glass as there was a crack in there so it was easy to rip up and take a look at whats going on in there. Let me tell you, its water logged for sure and I found milkshake oil in there from when the other motor mixed water in the oil and started coming out of the valve cover breathers lol.
Wish me luck and steer me in the right direction, thanks guys!
