1988 Penn Yan
Bob_VT
Re: 1988 Penn Yan
The company is out of business......
Good motor and outdirve but a gimbal bearing may only be the tip of the iceberg.........
Construction materials and quality is a bit questionable...... you need to investigate further for rot in the transom and have it checked carefully.
I just did a simple gimble bearing job with a friend and it was a simple nightmare :eek: It was a 1986 boat used only in fresh water but EVERYTHING was seized and the corrosion was horrible. Bearings, seals.....
I would look deeper into that boat.
