1988 OMC Sea Drive
Sea Drive
my friend has a 1988 sea drive 1.6L can not find manual release screw to raze motor up
clanton
Check the bottom of the valve body, also look at parts diagram.
F_R
Honorary Supreme Mariner
And there it is. #21
Auxlarry
The seadrive hydraulics are interesting. the control box is located inside the boat mounted on the transom...what issues are you having with it?
Auxlarry
You can access the relief screw through the lower plate on the mounting bracket...should be a hole in it like this...
