1988 Mercury Oil Injected Engine
RDS7
I just bought a 2nd hand boat and motor. The engine says oil injected. Ok, a stupid question ----does the mean I put the oil in a separate container or do I mix at 50:1 like I have for boats I've owned in the past? There are 2 gas tanks but nothing for separate oil.
lncoop
Re: 1988 Mercury Oil Injected Engine
Should be a separate oil reservoir. Oil injected means you don't have to mix. Mine is actually in the motor, but I have a 2002 model. What you need to do is move this to the Mercury section. You'll find out everything you need to know there. Welcome to iboats.
