wildchildc1
Thread starter- Joined
- Aug 29, 2007
- 2
I have a 1988 115 hp Mercury outboard that is hard to start hot or cold.. Its flooding itself on startup,.. then is loaded up and has to be cleaned out and then idles and runs perfectly thereafter. What it does is.. It fires right up, dies and will contine to crank unless you hold it about 1/4 - 1/2 throttle for about 4 or 5 seconds while cranking and it starts then dies and then after about two or three times of doing that it will stay running, its all loaded up, once it clears up after a few seconds, it runs great.. No problem loading up on idle, no hesitation. I have installed 6 new spark plugs and gone through all 3 carbs and made sure everything was adjusted to factory specs. Does anyone have any ideas on what I may do to correct this problem? Thank you
