Hi folks,
Took a chance and bought a Merc that sat a couple of years. Drained most of the old gas from the carbs and started it yesterday using high idle. I was able to lower the idle speed but the engine would misfire and it would stall at the lowest idle. Shot some carb cleaner into the two carbs but the misfire continued. Today, I pulled the plugs and checked the compression. Top cylinder was 120, middle was 130 and bottom was 130. I shot in some WD40 and the top one got up to 122. As for the plugs, the top one was baked Jet black. The other two were 'normal' looking (not white or black). I replaced the top plug with a new one and put the same plugs back in middle and lower cylinders. I started it just to burn off the WD40 and it ran better but still misfired and would stall at lowest idle. Tomorrow, I am going to replace the fuel filter and put new high octane gas in my tank along with some SeaFoam. Keep in mind that I only ran it a few minutes and there was smoke rising from the exhaust (likely the gas/oil I was using was also an old mix, regular octane).
Any thoughts on the black plug or the misfiring?
Can I test for a decent spark without some fancy meter or tool?
Would any carb adjustments help with the misfire?
Cheers
Cheers
