1988 Mercury 115 hp bubble
Sam Lindsey
1988 Mercury 115 hp want keep running unless you pump bubble. There seems to be no leaks (sucking air) so is this fuel pump?? I have replace bubble and checked it for leaks.
Chris1956
Re: 1988 Mercury 115 hp bubble
It sounds very much like a bad fuel pump. You can get a rebuild kit for that motor for a few dollars. Take the serial number to the Merc Dealer to get the correct one. Aos get a service manual to guide you on the repair. It is very easy, BTW.
MrLundt
I had a similar problem and figured it out w/ help from this i-boats forum.
http://forums.iboats.com/showthread.php?t=215710
Boat would run at 1/2 speed until I squeezed primer ball. Thought it was ball or fuel pump. Ended up being clogged jets on one of the lower two carbs. Soaked all carbs in 1 gal of chem dip and blew off w/ compressed air. Problem solved. You may try this or you may need new fuel pump. I had replaced mine a few yrs previously so I did not suspect it was the pump for me. Good luck!
Sam Lindsey
Thanks for the info! I had tear in fuel pump also soaked carbs in acetone blew them out and now runs like new!!:)
