hkeiner
- Oct 17, 2006
- 1,055
Re: 1988 Mercury 100hp w/ acceleration problems
The vacuum test and the pressure test should both be done using a T connection and with the motor running out on the water. You need to see if the meter readings are OK when the motor is actually bogging, otherwise you may not see any drop/spike in the readings. If the readings remain within spec while the motor is bogging, then you have eliminated a lot of possible causes related to the fuel system, although not all of them. That is making progress.
Also, be sure to confirm that there are no air bubbles appearing in the clear hose connected between the T-connector and the fuel pump during the above vacuum test.
If you want to check the ignition system, I have found that using a SmarTach meter to monitor secondary voltage in the spark plug wires is a fast and easy way to do this. The meter connects to the spark plug wires using an inductive connection, which can be easily moved from wire to wire while the motor is running and bogging. If the meter shows that the secondary voltage is dropping on one or more spark plug wires during bog, you can then use an ohmmeter and DVA meter (or other methods) to find out what exact component is failing. I bought my meter on ebay for under half or retail. The meter will not tell you which particular ignition component is bad, but it will tell you if the ignition system is failing or not during bog. That is making progress.
