alex3012red
Thread starter- Joined
- Nov 20, 2006
- 65
I have a 470 that was rebuilt,(new bearings .010, pistons are std,rebuilt head, new seals with reedy sleeve on water pump shaft. cleaned out 4" heat exchanger.(took ends off looked o.k) pressure washed it. new thermostat 160 deg. new impeller. no leaks either oil or antifreeze on cooling system. Can't get temp below 190 deg. idling and goes to 200 deg when running 3K or above rpm under load(2 adults). I removed the hose before the heat exch. too see if I was getting water from impeller, it seem a good flow.also tried to put more water in the heat exch. temp idling was still 185 deg. gets hot moving.
Can the heat exch. be taken apart? to clean out, seems clean to me but i can't see everything from the outside. Any expert help would be appreciated. thanks
