1988 Merc 150 V6
mtlmndr
I have a 1988 150 v6 on a 191 Mako. Its only a 20 inch shaft and the boat calls for a 25 inch shaft. I bought the boat as a package this way. I am wondering if I can put a longer mid section and shafts in this outboard to correct the problem? Thanks
Chris1956
Re: 1988 Merc 150 V6
There was a midsection spacer for that motor. You would need to locate a junker and remove it , or swap with someonw wgho needs a 20". You newed to changte the gearcase to get the longer shaft, the spacer, water tube extender, shiftshaft extender and longer midsection studs.
