1988 mariner 150hp need a good prop for fast speed
trevin11
What I have on there is 22p lazer II at Max rpm witch is around 5800 top speed is 47 I want to go faster than that boat is a 92 nitro
tannedman
Re: 1988 mariner 150hp need a good prop for fast speed
How long is the boat as i have almost the same setup but on a Skeeter its a couple years newer but my top speed is 66mph maybe have your compression checked first thats cheaper then going out buying different props
trevin11
Its 18ft long
sixstring531
This doesn't really help, but my 96 Astro (18ft) with a merc 150 on a jack plate was around 62-65 and I'm pretty sure I wasn't wide open. Too fast for me. The fish will always be there.
trevin11
The compression is fine checked it this morning
muskiemike12
Is that GPS speed or the gague on the dash that are notoriously wrong. That bost shoud be hitting 60 at those RPM's with no problem
gwukena
Has it always ran like this, or is this a new problem? Your showing about 27% prop slip, have you checked prop for a slipping hub? Has any setup changed ie: motor height,added transducers etc.. If too high prop could be ventilating too much,disrupted water flow to motor could cause this too (problems in bottom of boat, transducer mounting)
trevin11
Its always ran like that I did raise the motor about two inches to see if that would help and still nothing my local marine said try a 25p prop and a bigger hub size
gwukena
Did you buy this used or always owned it? Can you provide part #'s off of prop, does this prop have rubber hub or the newer style hub (plastic sleeve). I don't think that engine would turn a 25 pitch prop in your setup, what baffles me is the shop said run a bigger hub size. Almost sounds like you have a prop to gearcase mismatch. Hopefully the resident experts will chime in soon ie: faztbullet, charlieb etc
trevin11
I got it used the numbers on the prop rea d this 48 16992 a40rubber hub
