lgreen8303
Thread starter- Joined
- Nov 23, 2002
- 18
There is a port between the 3rd & 4th spark plug. It is a 1/8" brass pipe plug called the cylinder block cover pipe plug, per the manual. Can I remove the plug and install a 120-240 F. sending temp unit? I think this is where it should go but the manual leaves a lot to be desired. Thanks, the motor is a L6 115 hp.
