1988 Johnson idle problems
scottsissy32
any suggestions when the boat idles it tries to cut off and most of the time it does. changed the plugs, both gas filters, tstats. It runs great when you are cruising, but as soon as you put it in neutral it tries to cut out.???
Haffiman
Re: 1988 Johnson idle problems
The no 1 sign of a healthy engine is that it idles.
If not, the no 1 test to do is a comp test to check that the engine has a reasonable good balance in the combustion cycles.
More than 10% difference between cylinders and you might be in trouble.
So which engine and what are the comp readings?
scottsissy32
So which engine and what are the comp readings?[/QUOTE
It is a 115 V4. Havent checked the compression yet? any other suggestions. I was thinking the fuel pump?
Haffiman
That engine is in principle 4 individual engines stacked in a V-shape.
One or more is not working properly - which one?
Fuel pump is common for all of them, probably not.
Test compression, test with a spark-tester that you have spark on all cylinders as a start.
scottsissy32
ok i unplugged the oil injector so we can mix our own gas could that cause the fuel pump not to work correctly?
scottsissy32
apparently i just found out that the motor used to have an oil tank and the previous owner bypassed it and they just mix oil in with the gas in the tank
Haffiman
If it 'runs great when cruising', leave the pump for the time being and concentrate on the basic at the beginning.
scottsissy32
also when I turn the idle up it runs great, but when I turn it down thats when it tries to shut off. I am new at this, sorry for all the questions. I checked the compression when I first got it a few months back and it is fine.
scottsissy32
cant remember what the compression readings are but the plugs arent fowled out at all? Its very frustrating
Haffiman
Another advisor on this board has a sub-text to all his posting:
My questions needs an answer..
'Fine' is not an answer in this, but the real numbers today and not some time back.
Something like going to the doctor saying: I was ok last month, today I'm not. What is wrong????
Post back when you have the numbers and the spark test results.
