rammerjammer05
Thread starter- Joined
- Feb 17, 2011
- 52
I am having a fuel related problem with my Johnson 175 GT. At 1/2 - 3/4 throttle I'm having a fuel starvation and the motor will die out. I have replaced all fuel lines,VRO pump (mixing my own gas 50:1), primer bulb, checked for vacuum leaks, replaced all spark plugs, rebuilt carbs, new pulse limiter. Compression is 100psi on all cylinders. I can actually keep the motor running if I manually pump the bulb, I have a clear inline filter before and after the VRO pump. The filter before the pump stays full of gas but the filter coming out of the fuel pump to the carbs I can see gas being pumped into it but just seems like it's not enough especially at higher RPMs. Just all of a sudden started doing this about 3 weeks ago and I have checked or replaced everything I can think off. Am I'm missing something else.
