1988 Johnson gt 150 v6
isaac75
motor runs great on the hose but when its on the water it bogs down and won't do over like 10 mph. When the motor is put in reverse it gets this horrible clanking sound im new to this so any advise helps thank you
Honorary Supreme Mariner
I believe it just sounds great to you on the hose.-----They will all " bark and roar " even running on 3 of 6 cylinders.-----Start with a compression test.---Post the numbers.-----Then see if spark will jump a gap of 3/8" or more on all leads.
isaac75
Engine compression test done 6/19/2020
2- 55 psi
4- 60 psi
6- 55 psi
1- 55 psi
3- 0 psi
5- 0 psi
Remove cylinder heads for inspection.-----This is beginning to look like an overhaul is needed.-----Big $$$ may be needed to fix this.
