1988 Johnson 90hp remote throttle removal
stopper
I am trying to remove the throttle handle on a 1988 Johnson 90hp model J90TLCCA. The OMC remote throttle is different than the one I keep seeing on the parts diagram for that engine. I need to get the throttle arm off in order to replace the wood side panel. See attached pics for the one I have. Appreciate any help on what the trick is. IMG_3611.JPG IMG_3610.JPG IMG_3609.JPG
interalian
Never worked on one like that, but have you tried removing the three screws fom the back of the aluminum case? Probably a screw inside there.
stopper
I haven't removed those yet. I was hoping not to open up the aluminum housing if I didn't have to. It seems like a lot of the handles have a way of removing externally, but I cannot find any hidden screws on the handle itself. maybe I will pull off that cover to see if there is a screw on the inside of the hub.
